For your stated goals, a set of ID1000 injectors should suffice, and even leave you room to grow in the future. For a pump, you can go with a Walbro 450 and again, still have some room to grow in the future, without having to upgrade from it.
From an ECU stand point, you'll need any Honda OBD1 ECU from a Civic/Integra, that's been modified to accept a databoard. You can usually find these from places like Hondata, Xenocron Tuning, Neptune, etc. They offer these modified ECU's for sale from their website.
You'll also need to convert the vehicle to OBD1 via a conversion harness
You'll also need a tuning solution, which is the circuit board that plugs into the modified ECU. Again, these come from Hondata, Neptune, etc.
Typical Costs:
Hondata Tuning Solution: $500
OBD1 ECU: $200-$300 (stay away from eBay, FB Marketplace, etc. Purchase from a reputable place)
Conversion Harness: $50-$80
Injectors: $500-$550 (ID1050x version)
Fuel Pump: $100-$110
Although there's plenty more that you'll need besides the turbo kit itself, and the products that you inquired about (clutch, etc.), the above is the basics.
