I put together a "program" in excel that determines turbo performance calculations based on engine parameters.
If you input a horsepower goal along with various engine/turbo setup parameters, the spreadsheet will output calculations such as pressure ratio, boost, and mass flow. With this data, you can go to a compressor map and determine if that compressor is appropriate for your desired setup.
DOWNLOAD (right click and save as)
Compressor Maps
Keep in mind that I put this together just last night and part of today so there is more to be desired but it seems to do its job.
I had to guess suggested values for some of the parameters such as BSFC and pressure drops but it seems to work.
I'm running 8psi of boost and the spreadsheet calculated 9 psi of boost required for my horsepower output.
This is by no means an accurate simulation. Just a "well-educated guess".
BTW...some people relate the pressure ratio directly to boost and use a conversion factor. This is incorrect. As you'll see the compressor outputs a higher pressure than is seen at the intake manifold. It is the compressor output that is used to calculate the pressure ratio, not the MAP.
I'm finding that the VE% plays large role in the output.
I've heard that VE% for the B18c peaks in the range of 102-110%.This is speculation.
However, I have found the following...
S2000....112%VE
H22.......102%VE
The higher the VE for a given engine, the less boost required to meet a desired horsepower.
