Ive been researching the stuff to get for my 98 gsr for its tune up it has under 75k miles on it. I was considering piecing together parts but came across this kit on ebay. It includes:
timing belt (14400-P72-014)
timing belt tensioner (14510-P30-003)
water pump (19200-P72-013)
cam seals (2, 91213-PR3-004)
cam end seal (12513-P72-003)
crank seal (91212-PR3-003)
cylinder head cover gasket (12341-PR3-000)
spark plug tube seals (4, 12342-PT2-000)
cylinder head cover washers (8, 90442-P30-000)
distributor cap (30102-P72-006)
rotor ( 30103-P73-003
spark plugs (98079-56A7H)
ignition wire set (32722-P72-003)
air filter (17220-P72-000)
oil filter (15400-PLM-A02)
drain plug washer (94109-14000)
power steering belt (56992-P72-004)
alternator belt (31110-P72-004)
air conditioning belt (31110-PV0-004)
All for 434 dollars do you think I should do it all oem or still piece together my own.I have a guy close by that will be helping me do all the work so I just need the parts. Thanks in advance oh and I hope I posted this in the right forum.
Dan
Dan
