I followed the radio removal guide posted in the articles section but ran into a problem trying to remove the deck (the last step of the article). I got the armrest, and lower dash and ashtray out fine, but there is a small storage tray directly underneath the radio i cant figure out how to remove, which is blocking my access to the screws to remove the radio, does anyone know what i should i do?
going from the back...i used a straight drive ratchet (similar to a screwdriver) and just grabbed the bolts at an angle and turned, it worked...but your hand has very little space to turn...just gotta work at it, you can try an open ended wrench if you can't get a straight drive ratchet...just patience, acura built it to piss you off...remember that
The tray under the deck is screwed on to the deck itself. As I recall, you can't remove it before removing the deck. It took me hours to get those two screws out. Patience...and dig deep.
