1 - 2 of 2 Posts
I have a 94 ls teg and the problem is that it is harder to put it into gear and sometimes it doesnt want to go in at all. The most conserning noise is when i am stoped and i have the clutch down it makes a squeel and when i let off it stops. Also when I am shifting it grinds in to some of the gears i figured that thoughs were the sincros but not sure. thanks
The noise you hear is your throw-out bearing, its toast. When you relace your clutch (and you need to) the kit "should" come with a new one.
Do a search and you'll learn more.
1 - 2 of 2 Posts
