when the trans is cold it shifts and runs good. As soon as it warms up it doesn't move. Anyone know what it might be?
I went ahead and changed the title of this thread. Having it say "97 Integra" isn't assisting other members when they're searching about similar issues that they may have.
I assume you have an automatic transmission. Have you checked the fluid?
Yes automatic and yes fluid is good
I recommend changing the fluid even if you think it is good. I had the same issue, and it was fine after driving around with fresh fluid. Also when you change your fluid you have the opportunity to clean the drain plug (which is a magnet and probably has a lot of metal stuck to it)
