I need the torque specs on a couple of tranny bolts. The first are the bolts that bolt the differential to the final gear. The others are the bolts that bolt the tranny case together. If you know any of these, I would greatly appreciate it. If you have the Helms, thats were it would be and I have yet too buy one because of my budget.
tepid1 on Feb/07/06 said:
Quote: BSQ5 on Feb/07/06The transmission bolts are torqued to 47 ft/lbs. The final driver gear bolts are torqued to 74.5 ft/lbs.
This info is incorrect....
It sounds like he needs the casing not the tranny to engine bolt torque.
You are correct...I mis-read the original post. Thanks for catching that.
