right now i have 195/60/15h big-o euro tires on my fat fives.. and the front tires have been eaten up on the inside due to my car not having a camber kit. well i've since fixed that problem and now im wondering about something. would buying these tires in a 195/50/15h up front make any difference? as in would it mess up my speedo or anything like that? thanks.
there's a tire size calculator in the articles to check if it will mess up the speed.
and yes, if all you are changing is the aspect ratio, it will mess up the speed.
Just an FYI, the 195/50-15 size tires do not meet load capacity requirements for the Integra. Not that I'm saying that eliminates them completely, most don't care and run them anyway.
Is there some reason you can't get the 195 55 15's? That would put you at the stock diameter or close depending on the tire.
They offer that tire in the stock size of 195/55/15 so you should get that. You can get away with 205/50/15 as well.
There are many discussions on tire size as well, so I won't get into it.
