Recently my car left me stranded in a parking lot. Although the lights turned on the starter would not turn the engine over. Someone in the parking lot kindly gave me a push start and I was able to get the car home.
Sure enough I saw pieces of the clutch switch stopper on the floorboard.
I ended up removing the drivers seat and fished it into place using a piece of 24 gauge wire lightly looped around the tip and a loop formed at the other end of the wire. I fed the loop through the pedal box and used a screwdriver to do the final press in of the pad as I pulled the wire loose straight through the hole in the pedal. This method took me about 15 minutes after removing the seat.
