Ok, I searched but couldn’t find anything about this specific part. I’m in the process of bringing my gsr back to life and I’m refurbishing the front end suspension/brakes etc.. My tie rod ends (oem) are both still in decent shape but the boots are starting to crack/split. I was able to get two new oem tie rod end boots off eBay (number 14 in the diagram below, part number 53546-S84-003).
Issue is, the new boots don’t seem to fit flush onto the tie rod end. I think it’s due to number 15 in the diagram below that doesn’t have a part number
Does anyone have any experience replacing oem tie rod end boots? Or any knowledge of the number 15 ring/washer/circlip thing? Do I need to remove the number 15 thing in order to get the new boots on? Does the number 15 thing hold the boot in place? Any info is welcome.
Does it look like a metal clip? If you remove it you should be able to slip on the new boot and clip that piece back on.
Ok, I think i figured out what's going on here. I have a 2000 GSR which does NOT have a part number for #15 in the diagram. Turns out, it was a metal ring, but it was the bottom of the original boot. I was able to get it off with a flat head screwdriver and a hammer. I realized this after i took it off and noticed the underside of the new OEM boot looked exactly like the underside of the ring that was on the tie rod end.
I checked the parts diagram of a '94 LS and it has a different part number for the boot (53546-SH0-A01), as well as a part number for #15 (Circlip, Tie Rod - Acura (53548-SL0-A01)).
My guess is they updated the boot at some point to a new design (but never updated the parts diagram). The new boot has a metal ring built into the base of the boot instead of a circlip that held the boot into place (#15). I was able to get the new boots on by removing the old ring, then using the 32mm axle nut socket to lightly hammer the new boots into place.
