Again my Haynes manual makes this seem easy. It says to hold the tie-rod end with an open-end wrench and loosen the jam nut enough to mark the position of the tie-rod end in relation to the threads. Now where I am havin trouble is loosening tie-rod end jam nut. To me it seems like its stuck on there. Second of all I only have one open ended wrench that will even fit on this. Whats the size of the nut in mills? Do I have to use a standard open ended wrench?? Pullin it from the steering knuckle was cake. Its the other end
I spreayed PB blaster all over the inner tie rod end. Plz help I can't separate the two. Im a picture man. SO if possible plz help with some visualizations
