I installed a new larger throttle body on mah gsr and i used the original TPS and it works fine but I can't help but wonder if it's not allowing the car to reach its full potential. I tested the voltage and set it to the correct "closed" voltage but since the new throttle body TPS tab position is different from the OEM the "wide open" voltage is only about half of what it should be. I'm wondering if there's some fix or maybe a universal TPS that will let me set it so it can read voltage from .5 to 4.5. Current wide open reading is around 3.
Discussion Starter #5
No way, thats exactly what im saying. I have it calibrated correctly. It can only be calibrated correctly at either open or closed because the new postion limits its movement. The video doesn't do the full calibration, most likely because they know it can't be properly calibrated. It doesnt really matter, i can just cut out the adjustment holes to give it more room to move.
