1 - 9 of 9 Posts
1998 Acura Integra Ls Automatic sedan
I have an acura gen 3 sedan with a b18b1 non vtec motor/ auto trans and I'm curious what modifications you guys would suggest for a daily driver... I dont plan to build a racecar.. but I would like a more powerful output.
Run about the same set up have a cold air intake header an exhaust then you can slowly upgrade after that just put in stage 1 cams from skunk an adjustable cam gear an it runs well
you could build an LS/VTEC, beef up the rear suspension and have a fun car. Larger rear sway bar, 1-1.5” Conservative lowering springs, white line (cheap) or pci (expensive) rear trailing arm bushings, some decent struts and you’re good
Besides obvious things like quality performance tires and suspension upgrades, that will make taking corners faster, the best upgrade for "free power" is a manual GSR trans swap. That way you actually have use of the entire power band. An obd1 ecu with a chip tune can net you additional power as well. But not a basemap. An actual tune from a tuner with a dyno. After you install the basics like intake, header, & exhaust of your choice.
For a manual swap you need : trans, shift linkage, t-bracket, And a manual ecu or an obd1 auto ecu converted. Just one resister to de-solder.
Discussion Starter #5
... you may be the most teg educated member I have met... thank you for this I plan to put all of this into my budget plans for my baby
If your near the St Louis area take you on a quick ride this thing from 70-100mph pulls like a train! An still getting close to 30mpg
Discussion Starter #7
It's funny you say that I'm making videos traveling in my teg... if your interested we can schedule a st louis trip .... I have friends close by
1998 Acura Integra LS Auto
I saw your posting. Our cars are identical, and it sounds like we are on simliar paths. Except that my engine is cashed and I need to swap it out, and while I do that, I'm definitely going to swap for a 5-spd from the AT. I'll be curious to see how you fare. Please do post what you learn. I have a call in to JDM in FL to see what options they have to do the swap. Once I have an engine that runs, I'll likely be doing some of the things that have been recommended to you. -good luck
Mine pulls hard threw all gears just has issues at idle do to the cams, But its a fun little car no I need it to loose weight!
1 - 9 of 9 Posts
