get a new ecu and jumper. obd 1 is a lot easier to mess around w/
Neo on Jan/23/06 said:In my opinon, it has a resonator type affect. It makes it less raspy,
well a new ecu and jumper doesn't solve my problem. I'm running an OBD1 and the whole reason i want to do this is specifically for datalogging with a wideband sensor..daheechang on Jan/22/06 said:get a new ecu and jumper. obd 1 is a lot easier to mess around w/
I was just scratching my head wondering the same thing.MichaelDelaney on Jan/22/06 said:Quote: Neo on Jan/23/06In my opinon, it has a resonator type affect. It makes it less raspy,
how can it resonate when there is no chamber and holes to create the resonance?????
come on man...
b18GSRZ on Jan/22/06 said:I had a test pipe on my 95 ls. It sounded like a fake vtec in the upper high rpm. Definetly get it. You get a good 5 hp on it.
Quote: SurferX on Jun/15/02 Take a look at this test of a 2.5" Carsound cat vs 2.5" test pipe on an Integra Type R.
Yeah where's all that test pipe power I've heard so much about?
My conclusion from this, test pipe =![]()
JayDeeMDC2 on Jan/22/06 said:i'm content with the exhaust tone right now. It sounds strong a deep and i don't want to regret putting a test pipe if it damages something in the resonator... I know cheap exhausts are made of fiberglass and melt under a certain temperature... Does not have a cat lead to increasing temperture? and what do quality exhaust systems use for absorption in their resonators? (ie.spoon, mugen, hks,apexi, hytech, smsp) and what temperatures do they melt at?
that's quite interesting... any chance of you knowing what comptech is made of?silvertegGS on Jan/22/06 said:Quote: JayDeeMDC2 on Jan/22/06i'm content with the exhaust tone right now. It sounds strong a deep and i don't want to regret putting a test pipe if it damages something in the resonator... I know cheap exhausts are made of fiberglass and melt under a certain temperature... Does not have a cat lead to increasing temperture? and what do quality exhaust systems use for absorption in their resonators? (ie.spoon, mugen, hks,apexi, hytech, smsp) and what temperatures do they melt at?
actually... some of the more reputable brands still use fiberglass type dampening material. My spoon n1 has melted into a solid piece of fiberglass. When it was off the car i could shake it and you could hear the piece slide back and forth in the muffler. So its pretty much loud as hell. Some companies used a combination of steel wool type material and fiberglass. The steel material goes directly around the perforated piping and the fiberglass is outside of that. The steel helps to absorb more of the heat i suppose. I know The HKS dragger mufflers have fiberglass in them, i know a friend who had one and it blew out eventually, shooting black, blobs of fiberglass out the tail pipe.
my main purpose for testpipes is to pollute...LOLJayDeeMDC2 on Jan/23/06 said:my main purpose for getting a test pipe isn't for performance...
Word. Thanks for thinking about future generations and the planet's well-being.MichaelDelaney on Jan/23/06 said:Quote: JayDeeMDC2 on Jan/23/06 my main purpose for getting a test pipe isn't for performance...
TheGSRGuy on Jan/22/06 said:Test pipes make the car louder, and that's about it. They don't add any significant power (as shown in the graphs), and offer zero sound deadening.
TheGSRGuy on Jan/22/06 said:Quote: MichaelDelaney on Jan/23/06Quote: JayDeeMDC2 on Jan/23/06my main purpose for getting a test pipe isn't for performance...
JayDeeMDC2 on Jan/22/06 said:my main purpose for getting a test pipe isn't for performance... Here's my upgrades:
Comptech Ice Box, Comptech TIG headers, Comptech exhaust, Carsound OBDII cat, Hondata s300, P30, OBDII-->OBDI, FJO wideband...
As you can see i've already got a carsound cat, i really don't want to fork out another 150bucks for another cat or modify it. When smog time comes around i'll just throw it back on along with all the other OEM parts. I'm not concerned with making more HP out of a test pipe nor am i trying to make it any louder than it needs to be. A 2.25 test pipe will be a cheap solution without any custom work to my cat or my header to accomodate for my FJO wideband. But my main concern is what will it do to the absorption material in the muffler and resonator?
