I have a 1996 SE model which has an LS non-vetc engine. It is turbocharged and the turbo is leaking oil at high RPM. But if you just daily driven then it is ok. The turbo setup was not a kit. It was just being put together pieces by pieces. It have a rev-hard header, T3/T4 turbo, sparco intercooler,extneral wastegate, and blitz blow off. It have a inline fuel pump with stock injector, rail, and regulator. The wastegate was set to 8 psi boost. Is this too much for the stock items? Did this cause the turbo to leaks or what? Can I fixed the leak myself or do I need a new turbo. It is leaking right in the middle of the turbo.
