Okay, man, looking at that turbo, there's a lot you'd need to do to your engine. The wastegate is set from 10-18 psi, which would more than likely mean doing something to your itnernals. Though they say our engines can take 10-12 psi of boost on stock, unless its perfectly tuned, that's a real hazard. Also, that massive turbo is going to need an intercooler, and none comes with that kit, or at least as far as I could see. Basically, you'd be buying a lot more to make your engine able to handle that turbo...and of course, once that power is added, you might be getting into the zone where you need to start thinking about a new clutch, a better fuel pump, and a whole mess of other things.
If you just want a kick around turbo, I'd look for the GReddy kit, or even the beefier fmax/turbonetics T3/T4 hybrid.
Or, you can check out this link...there's a lot of info that can help you out.
Peace.
http://www.matt3t4.20m.com/photo5.html
EDIT: Clickable-->
Turbo Info
