1 - 2 of 2 Posts
I never listen to my radio, So I just want to put my power antenne on a switch/relay. I read the tutorial for this in the articles section, but my relay is different. does anyone know how to hook it up when the specs of the relay are as follows:
85 - " Ground is applied to terminal #85"
86 - "12V power is applied to terminal #86"
87 - " normally opened, connected to #30 when relay coil is energized"
87a "normaly closed, connected to #30 when relay coil is not engerized"
30 - "when coil is not energized 30 connects to 87a"
"When the coil is energized 30 connects to 87"
Thanks!
that schematic is known as a Single Pole, Single Throw relay and is the relay depicted in the article
and in english, that means:
- Pins 30 and 87a are connected when power and ground is NOT existant over 86 and 85
- Pins 30 and 87 are connected when power and ground ARE existant over 86 and 85
1 - 2 of 2 Posts
