I'm about to buy a teg with a 00' b18c swap and the kid told me it was running rich because he was running obd2 with no secondary o2 sensor and if i switch to obd1 my problems should go away. does this make sense? I think he said he was running a p2p 96+ ecu which is obd2. do i have to put the p72 in there or just get the other o2 sensor
EDIT!! he said hes runnin a jdm p72 everything is clean on the swap but the ecu!!
idk if this even makes sense.
thanks ti
im running p72 obd1 with 1 o2 on a 95 gsr head car runs perfect no malfuntion light obd 1 is the way to go its better for tuning and chipping or you could run a chipped p28 check them out on ebay
if the engine is stock then it should be ran with the matching stock ecu.
running an ecu from a different car will cause the engine to perform improperly, because its been told its something else. if that makes sense.
*to make things short if its a stock 00 gsr motor run it with a stock 00 gsr ecu*
