I have a 99 Integra GS-R. I noticed oil on the bottom of my supercharger. It may have come from the nose. It is hard to see a trail but it accumulated by the casing where the nose section bolts up to the rest of the charger. Has this happened to anyone should I be concerned. I've read that the blowers come overfilled and will leak out. This is the second time I have seen this. First time was a year after I got the charger and now which is 2.5 yrs later. If it was overfilled wouldn't have drained out the overfill by now? What should I do?
Call Moss Morotsports and start the warranty replacement/service process. Whatever you do, do not clean the blower off; leave it nasty. Let the "experts" tell you where it's leaking.
You're problem isn't very common.
what about a type of squealing noise? i've had it recently, and it's bugging me a lot, i'm *hoping* it's just one of the idler pulley bearing going out, b/c i've read about the blower's bearing going out, but that sounds like a hassle and a half... what's the best way to pinpoint where the squealing is coming from?
Discussion Starter #4
If you have a squealing noise most likely it is a loose belt? Hopefully it is!
