My teg sunroof works and it does open up but it creaks and makes lots of noise. SOmetimes, it sounds so bad that i think its not even gonna work nomore. Also it stutters while opening but closing is really smooth. What is the rememby besides getting a new roof or motor for it?
My sunroof would open fine but when closing it, it would go slowly and I'd often help pull it closed while it was making a lugging noise. Ended up though that all it needed was to be lubricated with some grease. Not sure what kind (maybe white lithium, I think it is) since I had the dealer do it and it was pretty cheap - a few bucks.
you probably want to clean off the runners first of all the old dust/bugs/debris in there and all the old lube too, since most of that stuff has probably dried out. then relube using some grease or 3-in-1 or what you have in your garage. good as new!
