Ok, just recently my car has started making this somewhat quiet knocking/clacking sound.
This only occurs with the engine in gear and while the engine is being placed under some kind of load, IE accelerating or engine braking. It's quiet enough that I cant really hear it unles i'm in first/second gear and accelerating below 3800rpm or so. If I coast on a smooth surface with it in gear, it wont clack until the engine starts slowing the car down or i accelerate again.
I know it's not valve tick because it doesnt do it in neutral, and I'm pretty sure the same goes for rod knock. Also, it seems to hollow of a sound to be a loud injector (plus it does it during decleration if the engine is slowing the car, and the injectors dont fire then)
So the only thing I can come up with is a loose or broken motor mount. I'm pretty sure I've had one for awhile (mostly due to a loud clack if I get on/of the gas really fast in 1st), but this sound is new, and once again is directly linked to the engine rpm and whether I'm accelerating/engine braking. All I can think of is that somethings wrong with a mount that the engine vibration is causing it to rattle around when i step on it.
Just looking for a second opinion as to what it could be. The worst possible scenario would of course be rod knock, but since it doesnt do it at idle or revving in nuetral, I think I can rule that out.
