*searched*
is the stock fuel pump good enough for 7 pounds of boost??? i have a 92 integra
thanx TI
It depends on the amount of use of that stock fuel pump. IF you're using it with an FMU and stock injectors, your setup should come with at least an INLINE pump to ensure that the FMU can work properly. If not, I'd upgrade to a larger one if not now, than soon. If budgets are a concern, a larger used unit from a 3rd gen should be able to work for you.. But at around 100 bucks, if you can afford to go turbo, you can afford to get a better fuel pump..
well im planning on running 450cc DSM injectors with am s-afc. yeah that is true if i can afford going turbo i can afford a fuel pump. but with those injectors and s-afc would it be coo for now?
The injectors aren't the problem. If the injectors can't grab enough fuel because of a bad pump, it's just a problem waiting to happen.
Don't forget your resistor box when you're planning the install of those injectors as well.
