The brake on the rear driver wheel of my teg seems to be slightly hung up all of the time. When I am at a light my car does not roll and when I take off I can feel it stick a little. I have been told that is a bad piston in my caliper. Do I need to replace the calipers or is there something else I can do?
I hear this is pretty common in integras and I had the same problem and had to get my caliper replaced.
you might be able to get the cylinder bore honed or get the piston refinished, then it might work. otherwise, replace the brakes.
Mine is a little older, but I was told by tha senior mechanic at my dealership "this is common". Integras with more than 80k it may happen. I had 95k and both rears were locked.
Replace the calipers. Don't wait for the other side to F up too.
