Here is my situation:
My car has been having trouble starting lately. It will make a "click" sound from under the hood whenever I push my s2000 starter button and it will do this anywhere from 5 times up to 30 minutes and then it will just magically start. I did some searching around and found the starter rebuild thread and that sounded exactly like my problem, so I switched out the contact points inside the starter and I thought everything was good for about 3 days and then it started doing the exact same thing. I removed the s2000 starter button thinking that might be the problem, but I just did that about 20 minutes ago so I can't tell if that fixed my problem yet. I also have a Deka EXT14 battery but I don't think that would cause any problems like this. I am thinking that it may be the starter solenoid but I wouldn't think that it would make the clicking noise if the solenoid is bad. Any help would be great.
