1 - 2 of 2 Posts
So I was leaving from the store and when I tried to turn on my car it didn’t turn on. I then tried a couple more times and it still wouldn’t turn on then after I decided to turn the key and rev up the engine then my car turned on . What could be the problem?
Too little info given.
Did it crank with no start?
Did the dash lights etc come on when you turned the key?
Did it make any weird noises before you shut it off?
Is this the first time this has happened, or has it happened before?
Does it just click when you turn the key?
Is the fuel pump priming consistently?
Help us help you.
1 - 2 of 2 Posts
