I've had this squeek for the past couple months, and I thought I could ignore it...but who am I kidding. I really don't know as to what this could be coming from. I was hoping maybe someone on here had a similar problem or whatnot and could help me out.
Its a very high pitched squeeking that sounds like its coming from the pedal area (could be somewhere else) that only occurs when I actually engage the clutch. It will squeek when I go over bumps...but only if I'm in gear. I found this to be quite strange. Furthermore, it ALWAYS squeeks right as I switch gears (in the release of the clutch pedal, and the depression of the gas ..in that whole transition part). Its not continuous...its just a damn squeek, or a squeek squeek. It also sounds when I let go of the gas, and push it down again...so in other words, everytime I put my foot on the gas (but only when in gear).
That's basically it. Hopefully, one of ya fellas can help me out here. Thanks.
Sounds like it could be your clutch master. Mine does the exact same thing. I checked and have a little leak near the pedal. I'm replacing mine this week. I got mine from ebay. for 65.00 its a Adler/Nissin unit and has OEM part numbers. Acura wants 150.00 for it. Also if ur clutch master checks out okay its possible it could be your clutch throw-out bearing as well. Just to throw some ideas your way.
hmm...how do i check my clutch master? I really have no clue. same goes for the throw-out bearing. what am i really looking for here?
and is this normal wear and tear stuff? or is it something that can be covered by my warranty?
