It has been a little under 2 years since I first compiled the spring/coilover specifications article. What I'm finding is that alot of members are contacting me with specifications for something that appear different than what we have in the article. I've decided that the article has become outdated, and isn't as reliable as it was 2 years ago. Alot has happened in the import community in the last 2 years and most of those companies have changed/improved their suspension line of products during that time.
So because Team Integra is THE resource for information about the Integra, we need our articles to be up to date and be nothing less than perfect. So we will start from scratch again on the spring/coilover specs article so it will be completely accurate again and contain more information than ever before.
Current obligations keep me from having the time to get on the phone to all these companies again to get spring information so I'm calling on all of our members to submit what spring information they have so our article can be completely current and up-to-date to allow our other members to make an informed decision on what suspension would be best for them.
Submit your info into this post here (don't submit by PM, my box will be full in a day
). What we're looking for is:
Springs, sleeves, or true packaged coilover
Front drop height (in.) (adjustable range if coilovers)
Rear drop height (in.) (adjustable range if coilovers)
Front spring rate (lbs/in) (adjustable range if true coilovers)
Rear spring rate (lbs/in) (adjustable range if true coilovers)
Progressive or linear spring rate?
Specs for springs of all generations 1-4 of Integras are welcomed so post what you got here and of course your name will go in the article along with it. We'll make that spring spec article bigger and better than ever.
