1 - 13 of 13 Posts
Discussion Starter #4
can someone post the skunk2 line up also. supposedly the stage 1s are 43 and the stage 2s are 49. i believe i posted those a while back. i got them from an source with no valid back up. anyone know if those numbers are correct? i've emailed skunk2 and they dont respond to their emails.i've emailed DPR, prospeed, alaniz, import builders..no luck
Discussion Starter #10
well, a source gave me this info for the spoon cams.
"Here's the specs for the Spoon cams:
Intake: BTDC : 15,5
ABDC : 60,5
Exhaust: BBDC : 42,5
ATDC : 22,5
at 1mm lift"
and since intake ABDC intake valve closing degree = Intake Cam Duration - Intake Valve Opening Crank Angle BTDC - 180 = 256 - 15.5 - 180 = 60.5
60.5 seems way too high, given the fact that toda spec Bs are 50. am i calculating this correctly? does 15,5 really mean 15.5? thanks
1 - 13 of 13 Posts
