1 - 2 of 2 Posts
Hi, what do you think about the skunk turbo cams working the drag turbo kit and the skunk IM. ? Of course the springs and retainers won't be left behind. (B18c)
I'd use a bigger IM plenum if I were turboing it like an STR or Venom one. The Skunk2 IM is ok but you can go bigger.
Do you have the specs for the Skunk2 turbo cams? I don't have them.
from Skunk2.com website camshaft section under Turbo cams said:
Turbo profiles are designed for engines with forced induction. Aggressive lift and valve opening/closing motions allow these cams to maximize power with a minimum amount of overlap.
1 - 2 of 2 Posts
