the coolant ducts and center flange hole do not line up for the ITR IM and the GSR head. Secondly, the GSR intake ports are taller...there is a more direct angle or shot into the combustion chamber and so the port on the ITR IM flange has to be aligned in such a way that it spits the difference in height between the 2 intake port heights.Apparently there is no vacuum leak when you split the difference.
Anyway, you can have a reputable machine shop weld shut the coolant ducts on the ITR IM or have them weld on material and reshape the ducts into the same alignment as the GSR head coolant ducts. The flange bolt holes can be slotted so they line up by the machine shop as well. Obviously they would need the head to align everything.
So by the time you cost out the ITR IM and machine shop work, is it cheaper than a Skunk2 IM?... depends on your machine shop and where you got your ITR IM...but in most cases probably not...certainly much more hassle for the average owner with no ties to machine shop work...
you need to get the Helms manual and look at the comparative IM's since the Skunk2 and ITR IMs needs you to buy an ITR throttle cable, cable bracket, new injector O-rings, GSR manifold gasket/TB gasket, and an ITR compatible intake.
You probably have a tapered 70mm TB since a true 70 mm TB on an N/A setup is way too big. If so, what is the diameter at the IM end of the TB? Some taper from 70->62 mm like a stock ITR TB, some taper from 70 -> 64mm, and some taper from 70->66-68 mm like Erick's TB's.....in which case you have to cut the TB gasket opening to the same diameter,...the Skunk2 and ITR IM port on the plenum which mates to the TB is 64mm in diameter. So if your TB diameter is larger than 64mm you must increase the diameter on the IM plenum port as well (called port matching).
