Hey guys, just got a pair of SIRII corner lights for 35 bucks. Hmotorsonline are cool guys. luckily im local to them. anyway two things i noticed.
1. Mine came with the bulbs and sockets with wire harness. and the main big bulb is different from our USDM bulbs. Also the sockets are different. they look similar but they are not.
JDM= 1 filament and socket has only 2 wires
USDM = 2 filament and socket has 3 wires.
Also the USDM sockets do NOT fit in the SIRII lights without modification. the little pieces of plastic that goes in and locks when you twist, well one is too wide for the JDM lights.
2. Our USDM corner lights look almost the same as these lights. the outer half of the lights has a yellow reflector. I wonder if anyone has tried to crack them open to remove the yellow reflector.
also when the JDM lights light up there are three things going on. the outer most corner, where the screw is, does not light up. next there is a small rectangular section of white light. then the amber portion lights up too.
I will post pics of mine later
