· Registered
2000 Acura Integra LS 1.8
Motor vehicle Hood Automotive design Automotive exterior Rim
Good day all, I have come into a snag and needing guidance/pics. I changed my header forcing myself to go single rad. I would like to tap into my existing wiring so it kicks on and off on its own without a manual interior switch. Can’t find much and I’m new to the forum and slow at navigating.
· Registered
Which is why I needed someone else’s brain. I’m over thinking things. Is it possible to only run one fan and keep a/c or do I need a secondary one and put it in the other side of the radiator. Thanks for your help.
· Registered
Yea you can do that. Will be the push and pull method. Make sure the fans are spinning in the same direction. ChaseBays has a dual fan relay kit you can get.
On mine, I run the push-pull method. You can either tap the other fan wires together or search YouTube on how to wire 2 fans.
· Registered
Just splice into the factory wiring harness for the fans. And it will operate as stock. Did the same thing to mine and works perfect and kept AC and PS too. View attachment 108465
Thanks man. I noticed you wrapped your a/c line as you can see mine is actually touching the header. Looks like I’ll be doing the same. Thanks for the picture.
