I have a 95 ls w/ 125xxx miles on it. for the past 3 months now, i always get a grinding noise shifting from 1st to 2nd. no matter what speed, or rpm Im at it will always grind gears if i shift too fast. for instance, even if i accel, push in the clutch all the way, and shift slowly (as in my arm moves slow) no grinding. but if i shift quickly, grinding noise. it seems whenever the car is moving, i cant physically shift fast. i expiermented by coasting and holding the clutch in all the way, and quick shift->grinds, slow shift->fine.
My quesition is this:
Is my transmission synchos messed up?
Or is it my Throw out bearing on the clutch?
Both?
Some help please.....thanx
Discussion Starter · #2 ·
could it possibly be the bearings in teh tranny or pressure plate/flywheel problem??
