so i finally got around to putting in a bosch relay to bypass my dual stage shock sensor that keeps going off when my 529T closes my sunroof when i arm my alarm (i have the 529T wired to clsoe the sunroof if it is open when i arm my alarm, the problem is, that the alarm is armed instantly and the sunroof takes a few seconds to close, and when it slams down shut it makes the shock sensor go off)....
the problem still occurs, alarm still goes off even though i am sure i hooked up the relay correctly. i wired it as follows:
12V constant --> Pin 86
Output during Activation From 529T--> pin 85
(-) Output From Sensor--> Pin 87A
(-) input to Alarm--> Pin 30
this is the only possible logical setup, i dont get why it wouldnt work...the output thru activation should show ground until the sunroof is completely closed, which should inclue the moment when it slams down at the end which is what is triggering the sensor...any ideas?
