A couple notes on this...
About a week ago I noticed a nasty squeaking sound coming from my rear right caliper. I checked out the pad through my wheel and noticed it was nearly metal on metal and the wheel was hot after only 5 miles of driving. I quickly checked the other side and it had about 70% life left, no squeak, no heat.
once lifted, I removed my right rear wheel and examined the problem. The rotor would not move whatsoever (brakes disengaged). I took off the caliper and analyzed. The piston would not retract, even after turning (as per article) it, pressing it with pliers, etc. After doing a bit of reading, I determined the caliper was seized.
I went to Advance Autoparts and picked up an OE caliper and rear pads for R+L. I installed, bleeded the lines and started the car. I pressed the pedal to regain feeling and the problem was fixed.
I've done about 50 miles since then and the pad feel is much better. I have no squeak, better acceleration (less resistance), and better mpg.
This post is purely to inform you of your problem if you have had similar signs of damage. This job was a 3 or 4 out of 10 for difficulty. I thought it was very easy IMO, with the article.
Good Luck.
Good Luck.
