I've gotten a couple hints and pointers on how to fix this but none seem to cure the problem. My seatbelt alarm has a mind of its own and beeps whenever it wants and sometimes will not stop for minutes/hours. Suggestions or a cure would be greatly appreciated.
I know in my old 91 civic under the seat were some plugs that you could unplug and get the beeping to stop.
on gen 2's there is a connector under each of the front seats. If this connector gets unplugged your dash light comes on and there is a annoying beeping. If there is no beepping then it might be broken or the fuse might be bad. Since you have a intermitent beep then I would say that the connector under one of the seats is loose and therefore makes the beep. Under hard braking in my second gen, the connector (which is worn from unplugging it to pull the seats out so often) actually comes unpluged. That starts a beeping and I have to stop and plug it back in.
