1 - 2 of 2 Posts
So, this just recently started happening, but whenever I'm driving, the door ajar light will turn on and the car will do the little ding telling me my door is open. I've checked every door and they're all shut. The weirdest thing about it is that it will turn off if I roll down the driver side window slightly.
The window trick throws me off. Not sure what that's all about. But aside from that, usually a faulty door ajar signal is caused by a malfunctioning button that the door is pushing on when its shut. See if the connection is loose on it. If the connection looks good, try switching the button with the one from the other door. If you determine that its the button then just replace it.
1 - 2 of 2 Posts
