you had an 'ideal' rod ratio of 1.75 how much can you then raise the redline too safely? This is assuming all the components are also needed in conjunction to raise your powerband or widen it and support the higher rpm of the engine...
Also, if you had this rod ratio, what are the affects of something like this and adding boost? Would this require a different sized turbo if the engine were also bored to a 2.0l? Because based on most of the threads i read it seems like the ideal turbo size for our engines is the t3's or the hybrid t3/4( I only have a basic understanding of the concepts above from the articles, so if anything i've said needs to be corrected, go for it, also i realize this is also part FI question, but i didnt wanna double post. )
