1 - 9 of 9 Posts
when your check engine light comes on for whatever reason the car can acutally go into safe mode right, how does your car work once is in safe mode
Safe mode?????????? All i know is that when your check engine light comes on you are stil allowed to drive it, Its not a safety issue, but most commonly and emmission issue.
What he means, I think, is that the car goes into "closed loop" mode. I still don't know what that means but I have heard that several timesbefore
my friend told me that if you have Vtec and your car goes into safe mode that your Vtec will not work. Not saying that is what happends but that s what i heard
its actuall open-loop mode,& what happens is your ecu goes to a default setting from the factory which does not use the sensor that is gone bad, in most cases, your teg will run rich.
1 - 9 of 9 Posts
