So, where exactly is this mounted? Where the cruise control button is?typeR430 on June/25/02 said:i have one..it mounts PERFECTLY where it fits on the s2000...i dunno how but theres a little spot for it..gorgeous fits cleanly on integs..installation was $30 at diamond bar honda
I don't even know why there is a cruise control button. I leave mine on all the time. All it does is allow you to turn the cruise control on using the buttons on the steering wheel, but if I don't want it on, I won't hit those buttons. Also, even if you hit the cruise control buttons accidently, unless you never use your breaks, then it won't be a safety problem either. So i'd say remove the cruise control button. But I agree, the dimmer dial is just as useless.TheGSRGuy on June/25/02 said:I would remove the dimmer....cruise control you would probably use, the dimmer button probably never. on JDM Integras the fog lamp switch is there.
