So my fuel and brake lines are all rusted to **** and are leaking. I dont want to do half ass splices so I'm ordering all new oem pre bent lines. Has anyone done this before? Can I do this and be able to reach both ends without removing or dropping other components? Any tricks or secrets to make this easier?? Its a 99'
Thanks
I did this on my 96 sedan. i think everything was still available except for the fuel vent line. that was discontinued and i had to make my own. I'm trying to remember what would have been in the way to do this. My car was completely stripped when i did mine. You'll def want to drop the fuel tank so you have room to remove the old fuel lines. I'm not 100% certain, but you might need to drop the subframe to install the the new lines. if the old ones are rusted, removal isnt a big deal, just cut them off. There might be some pictures of where the brake and fuel lines feed up through the front in my build thread.
If you have not done your repairs. 1 st I would take video and pictures, to go back and see how it was installed. even if it pre bent. you will need to see how it was installed. I start from the back incase you have to remove the gas tank. I found this youtube bit it may help.....
