i had my timing belt changed and it jumped i tooth. i drove it like that for a day. i took it back and they got it timed right . but after that the valves were making noise so i took it back and they said the valves were too loose
they tightened them to spec and since then it has been running rich and has a rough idle also loss of power in low rpm. could it being off i tooth and driving it for a day bent valve. could this be my problem. the motor i have in my car is a b18b1
is that 13.10 afr of 13 to 10 afr?
