my integra gsr 2000 runs on two cylinders and doesnt idle because of it i think, some sensors are unplugged because the block got forged.
it's turbo'd and will run around 300hp, but i still can't find what makes it run on two cylinders.
do you think its combustion, coils, injectors, or just the sensors?
1996 LS Manual Hatchback
First off, that pic is super small. Can you post a full rez one that we can look at more clearly?
Second, can you clarify what you mean by "your block got forged"? Do you just mean forged internals or did you literally have a new engine block forged out of a different type of metal from scratch? Either way, if it's still a B-series it needs most of the sensors plugged in to operate properly. What sensors are currently unplugged?
Have you checked that your spark is good on all 4 cylinders? Compression good on all 4? did you use a screwdriver or something else to listen to all 4 injectors to make sure they're steadily spraying fuel into the engine? What have you tried already to attempt to diagnose this?
