1 - 20 of 39 Posts
does anybody out there know how much it would cost to rebuild an LS engine so it could handle a SC and nos??? i figure the SC is around 3Gs the engine rebuild maybe 2Gs....then nos probably around 1G.....does ne one know if i am correct.....I don't know much about internals on an engine but all i know is that my B18B is goin to be FI with a JRSC and nos......i figure cams, rods, pistons, and other stuff should make my car hit 12's right???? please respond
NOS + JRSC is a bad idea....the nitrous gets on the blades in the jrsc and eats it up...sending peices of metal into your engine and therfore blowing it up into little tiny honda peices
The teamtoilet GSR had a JRSC with N2O no problem. I don't see how the N2O would eat up the blades?
Usually you want a small shot of N2O with a JRSC, to act as a cooling charge. I wouldn't use a 75shot on top of 6psi of boost on a JRSC.
if you want to run higer boost with the jrsc yoou are limited by the pully size. get a turbo kit from turbo-performance.com i talked to the owner about getting a turbo setup(few more weeks hopefully), he just got mail from a turbo teg ls owner with timeslips and pics. it ran 11.90's on slicks!! non intercooled kits on the website are 2400 ,3400 for intercooled, peice out the kit to what parts you want like i did and you could get a non ic w/out bov kit for just under 2k shipped. TURBO TURBO TURBO TURBO!!!
1 - 20 of 39 Posts
