Ok, so i have a 04 RSX base model and it wont crank. I took my starter off and got it checked out. It came back bad so i bought a new one and still it wont start. All my lights still come on, I switched batteries, checked fuses and it still wont crank over.
Any suggestions what it might be?
Are you sure you checked the correct clutch switch? There are two of them. I suspect the pad that pushes against the clutch switch when the clutch pedal is fully depressed. My 2002 wouldn't start last year and I found pieces of the pad on the floor. Part number 46505-SA5-000. Number 14 in the diagram is used for both clutch switches and the brake light switch. The one located top left is the one it would be.
Looking at the electrical diagram, the ignition switch, starter relay, and clutch switch all must be working. The relay is located in the under-dash fuse box.
Double check your connections at the starter. I wouldnt think 2 parts related to the clutch would fail at the exact time. If they are good maybe you just got a bad starter.
Another test you can do would be to jump the 2 terminals at the starter. This will force the starter to crank. If still no crank the starter is bad.
