1 - 11 of 11 Posts
Hey guys i have a 98 RS. By the driver side door handle there is a lock switch labeled hatch. This switch locks/unlocks the passenger side door and the hatch but not the driverside door. Is this normal. The passenger side door doesn't have a switch. Is the switch only for locking/unlocking the passenger side door and the hatch?
Thanks
i think all the 94+ RS have power door locks, maybe there is something wrong with that little motor thing that locks/unlocks on the driver side door, i think its called a solenoid
no .. My previous teg was a '95 RS and it definately did not have power locks ..
... And I dont believe the RS's ever came standard with power locks ...
I'm assuming what you have it some kind of an aftermarket addition that the previous owner of your car installed ...
crteg on Feb/02/06 said:
So on 98+ rs's you lock the hatch using the key? the lever on the floor of my car only opens the gas door.
What are you talking about? You posted that you have a switch that locks/unlocks the hatch.... you personally would use that and there is nothing else to be concerned about
Discussion Starter · #11 ·
hammock on Feb/02/06 said:
I have a 97 RS and it does not have power door locks.
The hatch and gas cover are lever controlled on the left floor near the door.
I was thinking he had a 98, so I was just a bit confused.
I just want to know if somebody has a 98+ RS that has a switch that is labeled "hatch". If so does it also unlock the passenger side door.
1 - 11 of 11 Posts
