1 - 9 of 9 Posts
Im kinda stumped on this one. at 1500 rpm's my b18c1 surges no matter the condition. hot, cold, in neutral parked, and in every single gear. I have spent $25 on brake clean from autozone looking for a vacuum leak plus a DIY smoker. I have brand new sensors as far as AFR would be related. Im kinda stumped. This is on a 2000 gs-r thats all stock except short ram, headers, exhaust, and its got a OBD1 P72 instead of the OBD2.
Did you check your IACV for cleaning or check the TPS to make sure it has correct voltage?
I replaced the TPS a while before this started happening. It reads .48 at idle and 4.5 at WoT with the 5v on red wire i believe. I even went and swapped the TPS with a new one and it still does it. The IACV is also a brand new autozone unit, i had some idle hunting so i replaced it and that went away with the IACV. I have used a pressure bleeder and also bled the coolant from cold to hot with the heater on max twice as well. I learned a lot with the idle hunting issue but this is crazy. I have also searched high and low about this issue and seen numerous posts but none of them have a answer besides something i have already checked. The engine literally has entirely new sensors, full ignition system from plugs to distributor and even the ignition switch wiring which powers the dizzy. I forgot to mention that it started a bit after i put the OBD1 ecu in but i cant say its the ecu because the TPS had a huge dead spot around 1500 and i replaced it after the ecu. My obd2 ecu is burnt up and wont allow the car to really drive but when i plugged it up to check if it would rpm hunt at 1500 it still did. Im literally stumped which doesnt happen hardly ever.
Incase someone finds this and has the same issue. It ended up being IACV transistor in the ecu had failed. replaced it with a used one out of another obd1 ecu and now the issue is gone. the location differs depending on ecu
It was easy in my situation, the transistor was visibly burnt up. I read somewhere that it can happen from switching the IAT, Power steering pressure switch, and/or the IACV plugs with each other. Considering it was a obd1 p72 that i got for $150 im sure the previous owner did something and damaged it. nowadays a decent obd1 p72 goes for a minimum of $400 and i have seen some units being sold for $700+.
How did you narrow it down to that component?
right before i figured it out i had tested every wire involved in the circuit and tried 3 different IACV's. Somewhere i came across a list of IACV components within a obd1 p72 ecu. in my case there was visible discoloration around that transistor. it was a little luck but i cannibalized a old p05 and swapped them out which fixed it. are you having a issue similar to mine?
sorry for the late reply, but not any more. My unusual rpm surge was due to a bad (new out of the box) distributor and some old spark plugs. Now I'm dealing with a p0170 and p0171 code with misfiring when the engine is cold (not started for a couple of hours).
1 - 9 of 9 Posts
