1 - 13 of 13 Posts
Yep... my motegi's are going to be repainted, by me..
Why do you ask? Well, the simple reason: I f**ked them up. I got myself a sanding machine and will sand down all of the wheel. Re-coat gunmetal 10-15 times. Then apply clear coat 5 times. I plan to make this job as professional as I can, I will be taking pictures as I go along :)
i agree, powdercoat is the way 2 go, but if u paint, 15 coats sounds way overboard, 2-3 coats each of paint and clear should b sufficient use some quality automotive paint and a good sandable primer
the plan sounds good, you should post an article, and i was wondering what kinda primer and what brand n type of gunmetal paint you are using, and also the clear coat, i've been into some kregen, they had sh*t, so i'm not sure which one to get..thanks, good luck on your project.
1 - 13 of 13 Posts
