remove the screw and switch them that easy,I'll go get you a pic for the other lightsIneri on Aug/22/02 said:i actually went and got clear corner replacement.how would i install that also.??
ineri
The low beam headlights are the same as high beam headlights as for removing and installing. Open the hood unscrew the lights and replace the bulbs. *Do Not Touch the Bulbs* and make sure that its sealed up tight when you put it back in, or you'll end up with water in your headlights.Ineri on Aug/22/02 said:i'm talking about low beam headlight bulb.
and i also want to replace front blinker too.
thanks so far though.!!
ineri
nope the lights themselves are aimed not the bulbs so your okayIneri on Aug/22/02 said:by the way - would i have to re-adjust the alignment of the headlights once i replace it's bulbs.??
ineri
mine left one is a little loose also,Ineri on Aug/22/02 said:i made sure the tab stuck into the whole and the screw went into the hole... but my corner lights are more loose then my stock.am i missing something.?
it looks secure but makes me feel uneasy on how much it budges.
ineri.
