is it possible to remove spray paint from a wheel yet leave the oem paint/clearcoat in tact under it? i used the tamiya model spray paint in a can.. i believe its acrylic.
ya i think ill try the claybar (tho i dont know how that would help- doesnt it only remove surface spikes and bits?), white polish, red rubbing compound.. lacquer thinner..
why lacquer thinner over other types of thinners tho?
You might want to try denatured alcohol. It may take off the acrylic without affecting the clear coat. I know denatured alcohol will not damage (powdercoat) clear coats.
It's a cleaning solvent and it can be found at Home Depot. I'm not 100% sure it will remove the acrylic, but it's much safer than acetone, thinner, or paint stripper.
ive been using the brown rubbing compound followed by the white polishing compound, but its a very lengthy and time consuming process. im just gonna repaint the suckers later.
1 - 10 of 10 Posts
